[GRASS-user] r.external across Windows and Linux
Sat Apr 18 17:46:12 PDT 2015
Blumentrath, Stefan wrote:
> We are now about to move our GRASS DB to a network storage so it can
> be accessed from both sides. When I created a test-DB on the network
> storage I had trouble using external data (r.external.out). The
> links to the data seem to be different between Linux and Windows...
> My question is: Is it in general possible to use external data
> linked to a GRASS DB which is accessed both from Windows and Linux
> boxes? Or is accessing one GRASS DB (or one mapset) both from
> Windows and Linux a problem in general?
It should work, but I don't know how much testing r.external.out has
received, particlarly on Windows.
If you can report specific details of any issues you've encountered,
they will be looked into.
