[GRASS-user] GRASS 7 and gdal-grass-1.11.2 plugin
John A Stevenson john.stevenson at ed.ac.uk
Tue Apr 21 09:14:06 PDT 2015
Hi Stefan,
Thanks for the quick reply.  Based on the discussion, I changed the
entries in my configure file from 7.0.svn to 7.0.0.  I also changed the
paths in the Makefile to the proj tables and created a directory for the
drivers.
sed -i 's/\.7\.0\.svn/\.7\.0\.0/g' configure
sed -i 's/etc\/ellipse/etc\/proj\/ellipse/g' Makefile.in
sed -i 's/etc\/datum/etc\/proj\/datum/g' Makefile.in
sudo mkdir /usr/local/share/gdal
CPPFLAGS="-I/usr/include/postgresql" CFLAGS="-O2 -Wall" LDFLAGS="-s"
./configure \
             --with-grass=/usr/lib/grass70 \
             --with-gdal=/usr/bin/gdal-config
make
sudo make install
The plugin now compiles and installs cleanly, but gdal doesn't seem to
be using it:
# gdalinfo --formats | grep -i grass
  GRASSASCIIGrid (rov): GRASS ASCII Grid
Do you know how I can make it use it, or how I can tell if it is even
looking for it?
Cheers
John
p.s. I had searched the developer list archives for gdal plugin, but
that thread didn't appear.
On 21/04/15 15:54, Blumentrath, Stefan wrote:
> Hi,
> This has been discussed on the developers list. Have a look here:
> http://osgeo-org.1560.x6.nabble.com/GDAL-GRASS-plugin-1-11-2-tt5196087.html
> Cheers
> Stefan
> -----Original Message-----
> From: grass-user-bounces at lists.osgeo.org [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of John A Stevenson
> Sent: 21. april 2015 15:45
> To: grass-user at lists.osgeo.org
> Subject: [GRASS-user] GRASS 7 and gdal-grass-1.11.2 plugin
> Hi,
> I'm trying to install the GDAL-GRASS 7 plugin in order to plot GRASS data in QGIS.
> I downloaded the source
> (http://download.osgeo.org/gdal/1.11.2/gdal-grass-1.11.2.tar.gz) and followed the instructions in the README.  When I try to configure with the following command:
> CFLAGS="-O2 -Wall" LDFLAGS="-s" ./configure \
>           --with-gdal=/usr/bin/gdal-config ```
> I get the following error:
> checking for G_asprintf in -lgrass_gis... no checking for G_putenv in -lgrass_gis.7.0.svn... no
> configure: error: --with-grass=/usr/lib/grass70 requested, but libraries not found!  Perhaps you need to set LD_LIBRARY_PATH to include /usr/lib/grass70/lib?
> This is the same error as described in the gdal-grass README, but the workaround (creating grass.conf in /etc/ld.so.conf.d with /usr/lib/grass70/lib, then running sudo ldconfig) doesn't help.  I have also tried patching the configure.in and Makefile.in source files using the patch from here: https://trac.osgeo.org/gdal/ticket/5852 without success.
> How can I point to compiler at the right place?
> *    OS: Linux Mint 17, based on Ubuntu 14.04 (Trusty).
> *    GRASS version : 7.0.0-1~exp2~trusty3 from
> ppa:ubuntugis/ubuntugis-unstable repository (installs to /usr/lib/grass70.  Also installed grass-dev)
> *    GDAL version: 1.11.1+dfsg-1~exp2~trusty from
> ppa:ubuntugis/ubuntugis-unstable repository (installs to /usr/bin)
> Thanks,
> John
> Dr John A Stevenson
> RSE/Scottish Government Personal Research Fellow (co-funded by Marie Curie Actions) School of GeoSciences The University of Edinburgh Grant Institute James Hutton Road Edinburgh EH9 3FE Scotland
> PHONE: (+44) 131 650 7526
> FAX:   (+44) 131 668 3184
> email: john.stevenson at ed.ac.uk
> twitter: @volcan01010
> web: http://www.geos.ed.ac.uk/homes/jsteven5
> blog: http://all-geo.org/volcan01010
> **ICELAND MOBILE: (+354) 8417106**
> The University of Edinburgh is a charitable body, registered in
> Scotland, with registration number SC005336.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Dr John A Stevenson
Grant Institute
James Hutton Road
Edinburgh EH9 3FE
Scotland
