[GRASS-user] Label vector map
Anna Petrášová kratochanna at gmail.com
Fri Aug 21 08:58:06 PDT 2015
On Fri, Aug 21, 2015 at 5:24 AM, henk witte <henk.witte at groenholland.nl>
wrote:
> Dear grass-users,
> I am trying to put labels in a polygon layer, but the rendering fails. The
> details are:
> *Problem signature:*
>   Problem Event Name:                        APPCRASH
>   Application Name:                             d.vect.EXE
>   Application Version:                           7.0.0.0
>   Application Timestamp:                     55ae1991
>   Fault Module Name:                          libgrass_driver.7.0.1svn.dll
>   Fault Module Version:                        0.0.0.0
>   Fault Module Timestamp:                  55ae17e1
>   Exception Code:                                  c0000005
>   Exception Offset:                                00002aa5
>   OS Version:
> 6.1.7601.2.1.0.256.48
>   Locale ID:                                             2057
>   Additional Information 1:                  0a9e
>   Additional Information 2:
> 0a9e372d3b4ad19135b953a78882e789
>   Additional Information 3:                  0a9e
>   Additional Information 4:  0a9e372d3b4ad19135b953a78882e789
> The command I use (through the GUI) is:
> d.vect --quiet map=AlleKavels at GoesShape attribute_column=Kavel_nr width=1
> font=romans label_color=black
> Any suggestions?
Perhaps if you could replicate the problem on North Carolina sample dataset
or provide your vector file, it would help identify the problem. Does it
happen with other vectors or attribute columns? Have you tried different
font or not specify it at all?
Anna
> Henk Witte
> Groenholland Geo-energysystems
> Valschermkade 26
> 1059CD Amsterdam
> T: +31 (0)20 6159050
> M: +31 (0)628176535
> E: henk.witte at groenholland.nl
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150821/df76bdb4/attachment.html>
