[GRASS-user] filtering csv file before input for v.in.ascii
Helmut Kudrnovsky hellik at web.de
Wed Aug 26 14:23:59 PDT 2015
hi Veronica,
Veronica Andreo wrote
> Hi Helmut,
> Did you download from GBIF site? Because there are 2 (that I know) R
> packages that allows you to download data from GBIF, and you can ask for
> "NO SPATIAL ISSUES" in the data (among other options), probably in that
> way
> you can avoid these coordinates that are in a different reference system.
> Does that make sense?? Ah! The packages are: rgbif and dismo
> If you want, I can provide an example... I just tried yesterday :)
> HTH,
> Vero
thanks for the R hints, rgbif and dismo works quite nicely.
I've just uploaded a new addon:
new addon: v.in.gbif to import GBIF species distribution data via GDAL
vector VRT
https://lists.osgeo.org/pipermail/grass-commit/2015-August/036932.html
the addon imports downloaded and unzipped GBIF data via GDAL vector VRT to
the location without filtering non-existing/false latlong coordinates. these
points ca may be edited by the information given in the column locality
later on.
testing and improving welcome. :-)
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/filtering-csv-file-before-input-for-v-in-ascii-tp5211340p5221319.html
Sent from the Grass - Users mailing list archive at Nabble.com.
