[GRASS-user] Unique IDs for network segments
Johannes Radinger johannesradinger at gmail.com
Thu Dec 3 05:19:40 PST 2015
Hi Moritz,
The two-step v.category approach (del + add) and an additional v.to.db()
 was the
right way. Now I have the problem that there are 3 categories reported for
one single line that got split into to (1 old cat + 2 new cats). The old
category is still
associated with attributes but the two new rows are empty. How can
I get an attribute table that contains only rows for the new cats with the
attribute information
of the old category?
Here a working example (in the NC location) for illustrating my problem:
### Import test line to GRASS GIS
echo "ORGANIZATION: GRASS Development Team
DIGIT DATE:   03/12/2015
DIGIT NAME:   -
MAP NAME:     test_lines
MAP DATE:     2015
MAP SCALE:    10000
OTHER INFO:   test lines
ZONE:  0
MAP THRESH:   0.500000
VERTI:
L  3 1
 641045.70521951 218398.66077254
 641049.6221644 218261.56770124
 641026.12049504 218155.8101891
 1     5" | v.in.ascii --o format=standard input=- output=test_lines
# Add attribute table to imported line
v.db.addtable map=test_lines
# Add some attributes to table including the original cat as attribute
v.db.addcolumn map=test_lines at fidimo_test columns="col1 INT, old_cat INT"
v.db.update map=test_lines at fidimo_test column=col1 value=42
v.db.update map=test_lines at fidimo_test column=old_cat query_column=cat
# Import Point
echo "100|641045.940579|218320.669742" | v.in.ascii --o input=-
output=mypoints x=2 y=3 cat=1
# Create network
v.net -s --overwrite input=test_lines \
points=mypoints output=test_net operation=connect threshold=25
# Remove existing cats
v.category --overwrite input=test_net type=line cat=-1
output=test_net_nocat option=del
# Add new cats
v.category --overwrite input=test_net_nocat type=line
output=test_net_newcat option=add
v.to.db map=test_net_newcat type=line option=cat columns=cat
The attribute table of the final vector (test_net_newcat) should contain
only two rows for
cat 1 and 2 with the original attribute information for both rows. Is that
somehow possible
in GRASS?
/Johannes
On Wed, Dec 2, 2015 at 4:55 PM, Moritz Lennert <mlennert at club.worldonline.be
> wrote:
> On 02/12/15 15:40, Johannes Radinger wrote:
>> Hi all,
>> I built a GRASS7 network using v.net <http://v.net>:
>> First, I used the 'connect' option to snap some points to my network
>> (using the -s flag)
>> Second, I used that first network and also added all nodes with the
>> 'nodes' option to get a final network.
>> With the 'report' option of v.net <http://v.net> I can report all edges
>> with their start and end end points. However, these edges of the final
>> network are based on the initial category values of the input vector.
>> How can I get the network split into single lines with unique IDs
>> between each node of the final network. In other words I want a report
>> of v.net <http://v.net> that contains only unique edge categories? I'd
>> like to write the output of v.net <http://v.net> into a new table and
>> assign lengths to each edge.
>> For example, at the moment, a line with cat=300 is confined by a start
>> node cat=1 and an end node cat=2. For that case v.net <http://v.net>
>> reports:
>> 300 1 2
>> If I connect a new node with cat=3 along that line and calculate v.net
>> <http://v.net>, it reports:
>> 300 1 3
>> 300 3 2
>> Any ideas/suggestions? Maybe I need to 'break' the network lines at each
>> node before running v.net <http://v.net>?
> How about v.category op=delete type=line followed by v.category op=add
> type=line ?
> Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151203/31c94d5f/attachment.html>
