[GRASS-user] Compilation issues on Scientific Linux 6.6
Markus Neteler neteler at osgeo.org
Mon Dec 28 06:11:26 PST 2015
sorry for the delay, some questions below:
On Thu, Nov 5, 2015 at 12:17 PM, Matthias Benedikt
<matthias.benedikt at boku.ac.at> wrote:
> Hi there!
> I'm trying to compile GRASS GIS and ist components (proj, libtiff, geotiff,
> geos, gdal, netcdf, hdf5, laszip) from source on Scientific Linux.
Same system here - do you use SL6 or SL7?
> I've done
> that routine like a 100 times on Ubuntu with root access
In general you don't need root access at all in order to compile GRASS GIS.
> where it worked
> fine. The current machine has a lot of restrictions, that might be one of
> the issues.
> This is my config:
> CFLAGS="-g" ./configure \
>  --prefix=/path/to/releasebranch_7_0/build \
>  --enable-64bit \
>  --enable-debug \
>  --enable-largefile \
>  --with-freetype --with-freetype-includes=/usr/include/freetype2 \
>  --with-gdal=/path/to/gdal-2.0.1/build/bin/gdal-config \
>  --with-geos=/path/to/geos-3.4.2/build/bin/geos-config \
>  --with-netcdf=/path/to/netcdf-4.3.3.1/build/bin/nc-config \
>  --with-openmp \
>  --with-proj-includes=/path/to/proj-4.9.1/build/include \
>  --with-proj-libs=/path/to/proj-4.9.1/build/lib \
>  --with-proj-share=/path/to/proj-4.9.1/build/share \
>  --with-python \
>  --with-readline \
>  --with-sqlite \
>  --with-tiff-includes=/path/to/tiff-4.0.6/build/include \
>  --with-tiff-libs=/path/to/tiff-4.0.6/build/lib \
>  --without-fftw \
>  --without-blas \
>  --without-ffmpeg \
>  --without-lapack \
>  --without-mysql \
>  --without-odbc \
>  --without-opengl \
>  --without-postgres
> This is the errormessage after make -j16:
> GRASS GIS 7.0.2svn r66747 compilation log
> Started compilation: Thu Nov  5 12:02:49 CET 2015
> Errors in:
> /path/to/releasebranch_7_0/raster/r.gwflow
ok, so here is the first issue, it may be related to GMATHLIB (lib/gmath/)
> /path/to/releasebranch_7_0/raster/r.param.scale
> /path/to/releasebranch_7_0/imagery/i.ortho.photo/i.ortho.rectify
> In case of errors please change into the directory with error and run
> 'make'.
> It already had some more errors, but those I could solve with various export
> PATH and LD_LIBRARY commands.
Mhh, perhaps something "bad" crept in. Please post the very initial
error if it still occurs with the current 7.0. If you can, take it
from SVN or the weekly snapshot.
> When I enter one of the dirs and try to do make, this happens:
> [user at l33 r.gwflow]$ make
> : && icc -L/path/to/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib
> -Wl,--export-dynamic
> -Wl,-rpath-link,/path/to/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib
> -o /path/to/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/bin/r.gwflow
> OBJ.x86_64-unknown-linux-gnu/main.o    -lgrass_gpde.7.0.2svn
> -lgrass_raster.7.0.2svn -lgrass_gis.7.0.2svn -lgrass_gmath.7.0.2svn
> /path/to/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib/libgrass_gmath.7.0.2svn.so:
> undefined reference to `__kmpc_reduce_nowait'
> undefined reference to `__kmpc_end_reduce_nowait'
> /path/to/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib/libgrass_gpde.7.0.2svn.so:
> undefined reference to `__kmpc_end_serialized_parallel'
> /home/lv70836/avaflow/src/releasebranch_7_0/dist.x86_64-unknown-linux-gnu/lib/libgrass_gpde.7.0.2svn.so:
> undefined reference to `__kmpc_for_static_init_4'
Which compiler do you use?
I am frequently compiling GRASS GIS on Scientific Linux 6 and 7
systems, no problems so far.
best
Markus
