[GRASS-user] Reconnecting vector attribution with Postgres/PostGIS
Markus Metz markus.metz.giswork at gmail.com
Mon Feb 2 05:36:12 PST 2015
On Mon, Feb 2, 2015 at 1:57 PM, Moritz Lennert
<mlennert at club.worldonline.be> wrote:
> On 02/02/15 13:37, Paul Shapley wrote:
>> Hi Grass 7 users.
>> I am trying to connect some vector layers with thier respective
>> attribute tables in postgres/postgis. The tables all connected under
>> version 6.4.4 but not since upgrading to version 7RC1 (on winxp in this
>> instance) they do not. It looks like Grass cannot find the database
>> password but it is present in 'db.login'. Has anyone else had this
>> happen? Here are the outputs:-
> Apparently there was a change in the db driver that has the effect of not
> allowing whitespace between the different connection parameters.
> GRASS64:
> db.connect driver=pg database="dbname=nc_grass,host=localhost" db.tables -p
> => OK
> db.connect driver=pg database="dbname=nc_grass, host=localhost"
> db.tables -p
> => OK
> trunk (7.1):
> db.tables -p
> => OK
> db.tables -p
> =>Error
> I don't know if this was intended. Please file a bug report.
Not intended. Please try trunk r64396 (update of db/drivers).
Markus M
> Moritz
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
