[GRASS-user] generalize polygons including holes
Robert Nuske rnuske at gwdg.de
Fri Feb 6 02:08:06 PST 2015
Hi Markus
> >>>> v.generalize does not distinguish between outer and inner rings, it
> >>>> simply goes through all boundaries and generalizes each one.
> >>> And this has always been the case or this is specific to GRASS7 ?
> >> This has always been the case.
> > Then why doesn't there seem to be any generalization happening for the
> > hole
> > boundaries of the test dataset with grass64release ?
> With the test dataset you provided, GRASS 6.4 does generalize the hole
> boundaries. I do not have the problem vector of Robert, so I can not
> say if the hole boundaries in that vector are generalized or not.
Please find attached a location with a test dataset (snipped of larger vector
map) and two images from generalizations carried out in GRASS 6.4.4
(6.4.4-1~trusty5 from ppa:ubuntugis-unstable) and GRASS 7.0
(7.0.0+1svn64474~ubuntu14.04.1 from ppa:grass-devel).
Blue layer is generalized and red one is the original both at 50%
transparency.
For me, the results from GRASS 7.0 look as expected (inner rings generalized)
but v.generalize in GRASS 6.4 seems not to treat inner rings.
GRASS 6.4.4
v.generalize in=test_data out=test_gen method=douglas thresh=5000
Number of vertices for selected lines reduced from 907 to 82 (9%).
v.generalize complete.
GRASS 7.0
v.build map=test_data
v.generalize complete. Number of vertices for selected features reduced
from 4605 to 451 (9%).
cheers,
  robert
Type: application/gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150206/2d5d5de5/attachment-0001.bin>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150206/2d5d5de5/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150206/2d5d5de5/attachment-0003.png>
