[GRASS-user] GRASS pygrass - composite
Nikos Alexandris nik at nikosalexandris.net
Thu Feb 12 02:29:02 PST 2015
I wonder if there is any idea/intention to built in kind of a check
mechanism for modules applicable to raster data.  This, and the Εxtent
concept as well, are most frequent problems/inattentions.
Nikos
On 12.02.2015 10:33, Pierric de Laborie wrote:
> Thanks for your input. This was probably the reason why. Grass
> defaulted
> the region to the raster with the highest resolution.
> 2015-02-12 9:23 GMT+01:00 Micha Silver <micha at arava.co.il>:
>>  On 11/02/2015 14:55, Pierric de Laborie wrote:
>>  Dear Pietro,
>>  I ran the same command with the highest level of verbose.
>> Unfortunately
>> it didn't give much more information when blocking at the
>> problematic step.
>>  I also started the same command from GRASS GUI on another debian
>> machine
>> and it got stuck also. It is like the installation on Debian Wheezy
>> doesn't
>> fully work (?)
>>  GRASS 7.0.0svn (222):~/Grass_test >* g.gisenv set="DEBUG=5"      *
>>  D1/1: G_set_program_name(): g.gisenv
>> D1/5: G_set_program_name(): g.gisenv
>> D2/5: G_option_to_separator(): key = separator -> sep = '/'
>>  GRASS 7.0.0svn (222):~/Grass_test > * r.composite red=B5 at PERMANENT
>> green=B4 at PERMANENT blue=B3 at PERMANENT output=mycompo*
>>  D1/5: G_set_program_name(): r.composite
>> D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT
>> /tmp/grassdata/222/PERMANENT/cell/mycompo
>> D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/WIND
>> D2/5:   file open: read (mode = r)
>> D2/5: G__read_Cell_head
>> D2/5: G__read_Cell_head_array
>> D3/5: region item: proj:       1
>> D3/5: region item: zone:       32
>> D3/5: region item: north:      3948015
>> D3/5: region item: south:      0
>> D3/5: region item: east:       841215
>> D3/5: region item: west:       0
>> D3/5: region item: cols:       841215
>> D3/5: region item: rows:       3948015
>> D3/5: region item: e-w resol:  1
>> D3/5: region item: n-s resol:  1
>> D3/5: region item: top:        1.000000000000000
>> D3/5: region item: bottom:     0.000000000000000
>>  This one input raster is huge. 840,000x394,000 = 331,000,000,000
>> pixels.
>> That's probably not what you want. If you have your region set to
>> match
>> this raster (rather than the others, which seem to be normal size)
>> then
>> that would certainly cause the machine to lock up.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos
