[GRASS-user] v.net parallelisation issues
Mark Wynter mark at dimensionaledge.com
Fri Feb 13 17:14:39 PST 2015
Hi Moritz, Stefan (and Marcus if you’re around?)
Every day is a new day.
Not IOPs, Not memory, Not CPU…   Hmm, how about reboot...
>> As you have suspected, I get no benefit from additional CPUs.
> Are you sure the problem is CPU-bound ?
I started by testing v.net (the maintenance module) in parallel - and observed pretty much linear scaling in performance over and above 2 parallel jobs.
So I then proceeded to test v.net.distance… and sure enough, it is now scaling.  Really different looking CPU performance profiles to yesterday, when it wasn’t scaling.  On top, all the v.net CPUs are humming at 50%, the other 50% used by pg processes.
Below are some iostat profiles of the different parallel test.
So v.net.distance does parallelise nicely.   The neatest way is to launch GNU parallel from within a single grass_batch_job.  I will write up on the grass wiki in the coming 2 weeks.
Mark
---------------V.NET ---------------
Single job
v.net
iostat 1
TOTAL SCRIPT TIME: 284
avg-cpu:  %user   %nice %system %iowait  %steal   %idle
          15.92    0.00   35.32    0.50    0.00   48.26
Device:            tps   Blk_read/s   Blk_wrtn/s   Blk_read   Blk_wrtn
xvde             18.00         8.00       744.00          8        744
xvdj              0.00         0.00         0.00          0          0
          20.00    0.00   34.00    0.50    0.00   45.50
xvde              9.90         0.00       633.66          0        640
          22.50    0.00   35.50    0.50    0.00   41.50
xvde              9.00         0.00       592.00          0        592
Two parallel jobs
v.net
iostat 1
TOTAL SCRIPT TIME: 397
          32.16    0.00   67.84    0.00    0.00    0.00
xvde             19.00         0.00      1024.00          0       1024
          39.50    0.00   60.50    0.00    0.00    0.00
xvde             19.00         0.00       912.00          0        912
          35.50    0.00   64.50    0.00    0.00    0.00
xvde             16.00         0.00      1024.00          0       1024
Four parallel jobs
v.net
iostat 1
TOTAL SCRIPT TIME: 388
          32.92    0.00   67.08    0.00    0.00    0.00
xvde             31.00         0.00      1952.00          0       1952
          33.83    0.00   66.17    0.00    0.00    0.00
xvde             35.00         0.00      2016.00          0       2016
xvde             61.00         0.00      4032.00          0       4032
---------------V.NET.DISTANCE ---------------
Single job
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 88
           4.00    0.00   21.00    0.00    0.00   75.00
xvde              0.00         0.00         0.00          0          0
           7.75    0.00   21.75    0.00    0.00   70.50
           6.27    0.00   22.56    0.00    0.00   71.18
xvde              4.00         0.00        56.00          0         56
Two parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 96
           9.02    0.00   40.85    0.00    0.00   50.13
          11.75    0.00   43.75    0.00    0.00   44.50
xvde              3.00         0.00        40.00          0         40
           9.50    0.00   40.75    0.00    0.00   49.75
Four parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 124
          17.96    0.00   82.04    0.00    0.00    0.00
xvde              3.00         0.00        32.00          0         32
          18.50    0.00   81.50    0.00    0.00    0.00
          21.50    0.00   78.50    0.00    0.00    0.00
xvdj              7.00         0.00        64.00          0         64
Eight parallel jobs
v.net.distance
iostat 1
TOTAL SCRIPT TIME: 122
          19.00    0.00   81.00    0.00    0.00    0.00
          19.50    0.00   80.50    0.00    0.00    0.00
          18.65    0.00   81.35    0.00    0.00    0.00
xvde              3.00         0.00        48.00          0         48
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150214/e1667718/attachment-0001.html>
