[GRASS-user] Importing DMSP-OLS in an Lat-Lon based Location
Nikos Alexandris
nik at nikosalexandris.net
Sat Feb 14 03:27:26 PST 2015
Nikos Alexandris:
>> What is exactly wrong when importing imagery from
>> <http://ngdc.noaa.gov/eog/dmsp/downloadV4composites.html> in a GRASS
>> LL-based Location?
>> gdalinfo for one image reports:
>> Upper Left (-180.0041667, 75.0041667) (180d 0'15.00"W, 75d
>> 0'15.00"N)
>> Lower Left (-180.0041667, -65.0041661) (180d 0'15.00"W, 65d
>> 0'15.00"S)
>> Upper Right ( 180.0041652, 75.0041667) (180d 0'14.99"E, 75d
>> 0'15.00"N)
>> Lower Right ( 180.0041652, -65.0041661) (180d 0'14.99"E, 65d
>> 0'15.00"S)
>> Center ( -0.0000007, 5.0000003) ( 0d 0' 0.00"W, 5d 0'
>> 0.00"N)
Even Rouault:
> The issue is that your image extends a bit beyond the dateline
> meridian at the
> west and at the east, which cause coordinate wrap-up.
> You could probably pre-process the image with gdalwarp/gdal_translate
> with
> something like:
> gdalwarp in.tif out.tif -te -180 -65.0041661 180 75.0041667
That seems to be enough. Thank you so much Even. Nikos
