[GRASS-user] Default method of rasterizing in v.to.rast
Markus Metz
markus.metz.giswork at gmail.com
Tue Feb 24 00:19:05 PST 2015
On Mon, Feb 23, 2015 at 1:05 PM, RichardCooper <richtcooper at hotmail.com> wrote:
> Hi,
> I'm trying to determine the default method of rasterization used by v.to
> rast.
> In the v.to.rast manual it states in relation to the -d option, that 'All
> cells touched by the line will be set, not only those on the render path',
> but I'm not certain which method is being used by default.
The -d option applies only to lines, default is only those on the
render path (thin line).
> I came across a paper by Biagi and Negretti
> <http://geomatica.como.polimi.it/workbooks/n2/articoli/lbmn.pdf> * which
> describes how by default vectors are rasterized in GRASS 5. The latter
> authors refer to the 'center' method as being the standard GRASS command in
> 5.0 (p. 4). Is this used in GRASS 7? From my observation (in the Map
> Display), by default, vector area appear to be rasterized if the center of
> the grid cell falls within the area boundary?
Yes, or the other way around: a grid cell belongs to the area where
the grid cell's center falls into.
Markus M
> I haven't checked through the code, but maybe someone has some knowledge on
> the history of v.to.rast?
> Cheers,
> Richard
> *http://geomatica.como.polimi.it/workbooks/n2/articoli/lbmn.pdf
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Default-method-of-rasterizing-in-v-to-rast-tp5189410.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
