[GRASS-user] What algorithm does r.drain use?
Takenori KANAI kanai at ube-c.ac.jp
Thu Jan 8 20:12:34 PST 2015
Markus N and Markus M,
Thankyou for your response.
I see. If on the first step, more surrounding cells have the same
minimum cost, which is the first cell encountered
used (like follows: a is greater than surraounding cells)?
I'm sorry the question on the abc.
2  2  2
2  a  2
2  2  2
Thanks
Takenori K.
> To my knowledge there is no scientific paper available related to the
> r.drain algorithm.
> It has been written by Roger S. Miller in 2001 (replacing an older and
> less functional version).
> You may see the internals here in the code base:
> http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.drain
> Maybe other users know more about this algorithm family?
> Best
> Markus N
> r.drain simply follows the lowest cost in the surrounding cells (must
> be lower than the current cell). If more surrounding cells have the
> same minimum cost, the first cell encountered is used.
> Markus M
HTML����������������������������...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150109/2536e7fd/attachment.html>
