[GRASS-user] SQLITE db locking problem
Markus Metz markus.metz.giswork at gmail.com
Tue Jan 20 13:31:35 PST 2015
On Sun, Jan 18, 2015 at 3:23 PM, Mark Wynter <mark at dimensionaledge.com> wrote:
> Hi everyone
> I’m having issues with SQLITE as the db driver - I encounter this BUSY
> warning.  Only occurs when patching a particular map, in this case
> “temp_nbt_cleaned" which is the largest of the datasets being patched.  If I
> work with smaller datasets, it works fine.  Pre-patching, SQLITE DB size is
> only 170MB.
> I’ve come across various threads reporting something similar with db
> locking.  But couldn’t find a resolution.
> I’m running grass70 on Centos65, hosted on AWS..  SQLite is version 3.6.23.1
I thought the official SQLite version for Centos65 (and Centos66) is
3.6.20. Could there be a conflict between the official version and
your version 3.6.23.1?
> This is the error message.
> GRASS 7.0.0svn (nodeclean):/var/tmp > v.patch -e
> input=temp_t_cleaned,temp_b_cleaned,temp_nbt_cleaned out=temp_patched
> Patching vector map <temp_t_cleaned>...
> Patching vector map <temp_b_cleaned>...
> Patching vector map <temp_nbt_cleaned>...
> WARNING: Busy SQLITE db, already waiting for 10 seconds…
> WARNING: Busy SQLITE db, already waiting for 20 seconds…
> etc
> etc
I can not reproduce the problem on Fedora 20 with SQLite 3.8.7.4 and
Scientific Linux 6.6 with SQLite 3.6.20. Are you using default db
connection settings for SQLite or is the GRASS SQLite database in a
non-standard location?
Markus M
> I encounter no problems patching the maps, including “temp_nbt_cleaned" if I
> use PG db driver, or DBF driver.
> building topology for vector map <temp_patched at PERMANENT>...
> Registering primitives...
> 1860504 primitives registered
> 9027638 vertices registered
> Building areas...
>  100%
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
>  100%
> Number of nodes: 1457611
> Number of primitives: 1860504
> Number of points: 0
> Number of lines: 1860504
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> Intersections at borders will have to be snapped
> Lines common between files will have to be edited
> The header information also may have to be edited
> v.patch complete. 3 vector maps patched
> I’m more than comfortable using PG in the backend, but I find v.out.postgis
> too slow when exporting the resultant dataset back to postgis (possibly
> because its simultaneously trying to read and write to the same db). I
> haven’t tested whether v.out.ogr quicker than v.out.postgis.
> Any assistance resolving the SQLite issue would be greatly appreciated.
> Kind regards
> Mark
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
