[GRASS-user] t.vect.observe.strds: OSError: [Errno 7] Argument list too long
Sören Gebbert soerengebbert at googlemail.com
Mon Jun 1 08:31:31 PDT 2015
The module t.rast.what in grass71 should not have this limitation and is
much faster. It does not create a STVDS as output, but plain text using
different formatting.
Best regards
Soeren
Am 01.06.2015 17:12 schrieb "RichardCooper" <richtcooper at hotmail.com>:
> A solution to this is to specify 'where' conditions under the optional tab,
> e.g.,
> start_time <= '20000'
> I determined this figure by trial and error - not sure if it is my computer
> system that is the limiting factor requiring this be done in batches.
> http://osgeo-org.1560.x6.nabble.com/t-vect-observe-strds-OSError-Errno-7-Argument-list-too-long-tp5208418p5208498.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
-------------- n�chster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150601/5d0101b3/attachment.html>
