[GRASS-user] Issue with netcdf import into GRASS 7
Thomas Adams tea3rd at gmail.com
Tue Jun 9 03:51:21 PDT 2015
Markus,
Thank you for the suggestion.
Best,
Tom
On Tue, Jun 9, 2015 at 3:45 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Jun 9, 2015 at 4:47 AM, Thomas Adams <tea3rd at gmail.com> wrote:
> > All:
> > Using the help found here: http://grasswiki.osgeo.org/wiki/NetCDF I have
> > been able to import a netcdf file into GRASS 7, but the data is not
> scaled
> > correctly.
> > This is my import command:
> > r.in.gdal input=NETCDF:"geo_em.d02.nc":GREENFRAC output=greenfrac -o -e
> > --overwrite
> > which produces..
> > Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
> > I am virtually certain the lower left corner is placed correctly,
> because I
> > can zoom to the lower-left location and it falls about where it should --
> > however the spatial extent of the data is not what it should be, but when
> > zoomed-in looks correct.
> Tom, I believe that the gdal list is the right place here since the
> netCDF file is not read properly.
> Once solved, r.in.gdal will run out of the box.
> Perhaps they could give you hints how to convert the file with
> gdalwarp into e.g. a GeoTIFF which you can then import without
> problems.
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150609/36fdf8a9/attachment.html>
