[GRASS-user] Problem in lidar tutorial
Martin Landa landa.martin at gmail.com
Fri Mar 6 02:10:29 PST 2015
2015-03-06 8:21 GMT+01:00 Gaurav Parida <gparida94 at gmail.com>:
> Command 'd.vect map=elev_lidlast_clean siz=2' failed
> Details: Sorry, <siz=> is ambiguous
> What I can't figure out is, that is the command working properly or not. I
> am using Grass 6.4.4 on windows 7 (64 bit).
`siz` is ambiguous because there two options starting with `siz` ---
`size` and `size_column`. So you need to type `size`. I fixed
tutorial on wiki. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
