[GRASS-user] v.what.vect interface listing table columns from wrong layer
Daniel Victoria daniel.victoria at gmail.com
Fri Mar 6 12:50:40 PST 2015
Hi all,
Using Grass7 n wndows (osgeo4win).
I'm running v.what.vect and in the GUI, when I select the query column, the
columns shows are the ones from the layer to be update and not from the
query layer.
I can run the command correctily if I type the correct query column name.
It's just the dropdown list that is incorrect.
Cheers
Daniel
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150306/c5be1469/attachment.html>
