[GRASS-user] [GRASS-dev] QGIS GRASS Plugin Upgrade Crowdfunding
Radim Blazek radim.blazek at gmail.com
Tue Mar 24 23:52:00 PDT 2015
On Wed, Mar 25, 2015 at 12:44 AM, Daniel Victoria
<daniel.victoria at gmail.com> wrote:
> Hi Radim,
> I'm using grass 7 and QGis installed from OSGeo4Win so maybe it was compiled
> against some old libraries? I've no idea how to compile in windows so I'll
> just try to re-install everything and hope things work...
QGis from OSGeo4Win is compiled with GRASS 6, you cannot get it
working with GRASS 7. Reinstalling will not help. The provider and the
plugin has first to be fixed to support build with both GRASS 6 and
GRASS 7.  This is in the first package of proposed upgrade:
http://www.gissula.eu/qgis-grass-plugin-crowdfunding/
Then a bat to start QGIS with GRASS 7 could be added also to OSGeo4Win.
Radim
> Daniel
> On Tue, Mar 24, 2015 at 4:18 PM, Radim Blazek <radim.blazek at gmail.com>
> wrote:
>> On Tue, Mar 24, 2015 at 5:31 PM, Daniel Victoria
>> > Hi Radim,
>> > Is this why my QGis crashes when i try to load a Grass 7.0 vector file?
>> > [1]
>> AFAIC, it should only crash if you try to open a GRASS mapset with
>> GRASS 6 vectors in QGIS browser compiled and run with GRASS 7
>> provider. It is described here:
>> http://lists.osgeo.org/pipermail/qgis-user/2015-March/031177.html
>> I think that I know already what the problem is. If GRASS 7 lib is
>> tries to open a vector which it is not in format 7, it calls
>> G_fatal_error(), which normally opens a warning dialog. Because items
>> in the browser are populated in threads, it happens on non GUI thread,
>> but to open a dialog with an icon, it has to use QIcon which can only
>> be used on GUI thread.
>> Radim
>> > Thanks
>> > Daniel
>> > [1] -
>> > http://gis.stackexchange.com/questions/138477/loading-grass-7-0-vectors-in-qgis-broken
>> > On Tue, Mar 24, 2015 at 11:47 AM, Vaclav Petras <wenzeslaus at gmail.com>
>> > wrote:
>> >> On Tue, Mar 24, 2015 at 5:56 AM, Radim Blazek <radim.blazek at gmail.com>
>> >> wrote:
>> >>> >> Are there functions in time series implementation which need to be
>> >>> >> called directly from the plugin or everything may be done just
>> >>> >> calling
>> >>> >> t.rast.* modules?
>> >>> > Most of the temporal functionality is available through the temporal
>> >>> > modules. However some important algorithms (temporal re-sampling)
>> >>> > are
>> >>> > available only in the Python framework. This is needed for time
>> >>> > series
>> >>> > animation creation. Using the framework directly will speed things
>> >>> > up,
>> >>> > because the module calls, the parsing and interpretation of the
>> >>> > module
>> >>> > outputs can be avoided.
>> >>> If it should be used for dynamic animation in QGIS canvas you could
>> >>> consider the possibility to subclass raster renderer in Python and
>> >>> insert it into raster layer pipe from Python plugin.
>> >> Speaking about animations, some things from GRASS GIS GUI could be
>> >> perhaps
>> >> used directly in the same was as Tcl/Tk NVIZ is used in processing for
>> >> GRASS
>> >> 6. Animation tool is one of them. This would be great since we would
>> >> get al
>> >> least some functionality/code sharing between GRASS and QGIS GUIs which
>> >> is
>> >> otherwise not possible due to Python/wxPython and C++/Qt (and would be
>> >> only
>> >> possible if both things would be at least in the same language).
>> >> This is of course not fulfilling the requirement to be general, i.e.
>> >> work
>> >> with other data providers in QGIS, but surely some things just have to
>> >> be
>> >> like that if they are using GRASS-specific formats (temporal data) or
>> >> algorithms (e.g. algorithms to work with temporal data, their topology,
>> >> Vaclav
>> >> _______________________________________________
>> >> grass-user mailing list
>> >> grass-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/grass-user
