[GRASS-user] GRASS GIS 7 Error when launching
Markus Neteler neteler at osgeo.org
Thu Mar 26 03:26:39 PDT 2015
Hi Wolfgang,
please keep the list in CC - I am not much expert on Windows but others yes.
How did you install it? Standalone or OSGeo4W?
thanks
Markus
On Thu, Mar 26, 2015 at 11:01 AM, Dipl.-Ing. Wolfgang Figura <figura at uih.de>
wrote:
>  Hi Markus,
>  When I start the GRASS GIS 7.0.0 Command Line I get the following message
>  FEHLER: Unable to start GRASS. You can:
>  - Launch GRASS with '-gui' switch ('grass70 -gui')
>  - Create manually GISRC file
> (C:\Users\Wolfgang_2013\AppData\Roaming\GRASS7\rc)
>  - Launch GRASS with path to the location/mapset as an argument ('grass70
> /path/to/location/mapset')
> Beende...
> Drücken Sie eine beliebige Taste...
>  I can't enter any text in the command line, I can't copy-paste the
> message so I have write the text manually
>  thanks
>  Wolfgang
>  Am 25 Mar 2015 um 18:48 hat Markus Neteler geschrieben:
>  On Wed, Mar 25, 2015 at 5:55 PM, Dipl.-Ing. Wolfgang Figura
> <figura at uih.de> wrote:
> > Hi grass-user list,
> > when I try to lauch WinGrass 7 with the sample Data 'Spearfish'
>  Can you please also post the precise version number? You get it in the
> command tab with
> g.version -g
>  (text copy-paste preferred over screenshot for this)
>  thanks
> Markus
>  *Dipl.-Ing. (FH) Wolfgang Figura*
> Geschäftsführender Gesellschafter
>  Tel.-Durchwahl: 05271-6987-13
> E-Mail: figura at uih.de
>  [image: graphic]
>  *Mehr Informationen über unser Planungsbüro finden Sie unter *
> *www.uih.de* <http://www.uih.de> *.*
>  *Bitte denken Sie an die Umwelt, bevor Sie diese E-Mail ausdrucken.
> "Fast jeder*
> *zweite industriell gefällte Baum weltweit wird zu Papier verarbeitet"
> (WWF 2013).*
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150326/aef48787/attachment-0001.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150326/aef48787/attachment-0001.obj>
