[GRASS-user] GRASS 7.0.0 r.horizon only outputting the last angle raster for mode 2
Morrison, Bailey Danielle bdmorri2 at illinois.edu
Fri May 1 12:46:30 PDT 2015
Hello,
My lab recently just updated GRASS to 7.0.0 from 6.4.3 and I am having an issue getting r.horizon to run correctly. For some reason when I use mode 2 only the last angle that is calculated for the horizon rasters is outputted. For instance, if I set the angle step parameter to be 90 degrees, starting at 0 and ending at 360, I only get one raster output (for angle 270). I did not have this problem in version 6.4.3. Is there some new parameter to get all the rasters that were calculated?
My code: r.horizon -d --overwrite --verbose elevation=dem_mos2 at PERMANENT step=90 maxdistance=10 output=test1
Bailey Morrison
Graduate Student
University of Illinois at Urbana-Champaign
Integrative Biology, PEEC
Global Environmental Analysis and Remote Sensing Lab
