[GRASS-user] GRASS crashes while running i.atcorr
Markus Neteler neteler at osgeo.org
Mon May 4 13:41:46 PDT 2015
On Mon, May 4, 2015 at 7:11 PM, Jake Chila <jake.chila at gmail.com> wrote:
> Hi all,
> So I think I have managed to fix my problems with help from Markus and
> Nikos. As it turns out my issue was predictably (and embarrassingly) quite
> simple. In my parameters file both the month and day variables were in float
> format and so had the decimals after them which I think caused some problems
> in the program.
> I also found an old email in this list which said to convert the DEM to an
> integer so I also did that.
(... this surprises me - would not expect that).
Glad you got it running.
> Part of my project will be to compare the results from i.atcorr to those
> produced by the Atmospheric Correction Module in PCI Geomatica and so if
> there is interest I would be happy to post my results!
Definitely!
best,
Markus
