[GRASS-user] grass program compilation
alassane toure atourej at gmail.com
Wed May 6 09:06:47 PDT 2015
Correct!  Configure did fail ....unable to locate FreeType includes.
checking for location of FreeType includes...
checking for ft2build.h... no
configure: error: *** Unable to locate FreeType includes.
Any suggestions from this point?  Thanks!
Alassane
On Wed, May 6, 2015 at 9:59 AM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> On Wed, May 6, 2015 at 11:53 AM, alassane toure <atourej at gmail.com> wrote:
> > Group,
> > I am still not making any progress compiling Grass70 on Ubuntu.  Here is
> where i am at:
> > 1. able to run configure without any problem (with your help);
> > 2. unable to compile using the following commands:
> > make -j2  &&  sudo make install  &&  sudo ldconfig
> > And the system response was ....
> > include/Make/Vars.make:1: include/Make/Platform.make: No such file or
> directory
> > make: *** No rule to make target `include/Make/Platform.make'.  Stop.
> What was the output of configure? Perhaps it fails. Make cannot find a
> makefile which should be generated by configure.
> Note that for running make, you need to be in the directory with the
> source code (as needed for configure).
> > Your help is appreciated.
> > Alassane
> > On Tue, May 5, 2015 at 2:13 PM, alassane toure <atourej at gmail.com>
> wrote:
> >> Great! ./configure worked!   However compilation and installation did
> not.
> >> I run the following command:
> >> and the system response was:
> directory
> >> I appreciate your comments/suggestions.
> >> Alassane
> >> On Tue, May 5, 2015 at 2:03 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >>> On Tue, May 5, 2015 at 9:59 PM, alassane toure <atourej at gmail.com>
> >>> great!
> >>> > However compilation and installation did not.
> >>> > directory
> >>> please send it to the list, I am on Fedora...
> >>> Markus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150506/5f3521eb/attachment.html>
