[GRASS-user] grass program compilation
alassane toure atourej at gmail.com
Wed May 6 18:35:54 PDT 2015
Thank you all for your help.  The compilation went through without any
error!
Now I need to compile an example program.  I hope your help will not be
necessary.
My regards,
Alassane
On Wed, May 6, 2015 at 3:39 PM, Blumentrath, Stefan <
Stefan.Blumentrath at nina.no> wrote:
>  Hei Alassane,
> As a general strategy, when I get this kind of compilation errors I use
> the locate command in order to find the file ./configure is searching for
> in this case:
> locate ft2build.h
> It will print the folder where this file can be found on your system (if
> the relevant module/package is installed), so you can point ./configure to
> that, like Eric showed. If locate does not find the required file either,
> you are missing the module/package and have to install it in order to meet
> the dependencies.
> Cheers
> Stefan
> *From:* grass-user-bounces at lists.osgeo.org [mailto:
> grass-user-bounces at lists.osgeo.org] *On Behalf Of *alassane toure
> *Sent:* 6. mai 2015 18:07
> *To:* Vaclav Petras
> *Cc:* GRASS user list
> *Subject:* Re: [GRASS-user] grass program compilation
> Correct!  Configure did fail ....unable to locate FreeType includes.
> checking for location of FreeType includes...
> checking for ft2build.h... no
> configure: error: *** Unable to locate FreeType includes.
> Any suggestions from this point?  Thanks!
> Alassane
> On Wed, May 6, 2015 at 9:59 AM, Vaclav Petras <wenzeslaus at gmail.com>
> wrote:
> On Wed, May 6, 2015 at 11:53 AM, alassane toure <atourej at gmail.com> wrote:
> > Group,
> > I am still not making any progress compiling Grass70 on Ubuntu.  Here is
> where i am at:
> > 1. able to run configure without any problem (with your help);
> > 2. unable to compile using the following commands:
> > make -j2  &&  sudo make install  &&  sudo ldconfig
> > And the system response was ....
> > include/Make/Vars.make:1: include/Make/Platform.make: No such file or
> directory
> > make: *** No rule to make target `include/Make/Platform.make'.  Stop.
> What was the output of configure? Perhaps it fails. Make cannot find a
> makefile which should be generated by configure.
> Note that for running make, you need to be in the directory with the
> source code (as needed for configure).
> > Your help is appreciated.
> > Alassane
> > On Tue, May 5, 2015 at 2:13 PM, alassane toure <atourej at gmail.com>
> wrote:
> >> Great! ./configure worked!   However compilation and installation did
> not.
> >> I run the following command:
> >> and the system response was:
> directory
> >> I appreciate your comments/suggestions.
> >> Alassane
> >> On Tue, May 5, 2015 at 2:03 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >>> On Tue, May 5, 2015 at 9:59 PM, alassane toure <atourej at gmail.com>
> >>> great!
> >>> > However compilation and installation did not.
> >>> > directory
> >>> please send it to the list, I am on Fedora...
> >>> Markus
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150506/ee7ce215/attachment.html>
