[GRASS-user] Grass 7 and 7.1 r.surf.idw problem
Robert Kuszinger kuszinger at giscom.hu
Mon May 18 00:36:55 PDT 2015
Dear Markus,
thanks for the comments, I'm already taking part in the ticket handling
mentioned above with testcase creation and testing. It seems that 7.0
problems solved at r65214 <https://trac.osgeo.org/grass/changeset/65214>,
I'll test it further.
Very good community, anyway :)
Robert
2015-05-17 19:28 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> On Thu, May 7, 2015 at 12:28 PM, Robert Kuszinger <kuszinger at giscom.hu>
> wrote:
> > (I'm sorry for the previous one going out without subject)
> > Hello,
> > I've tried to use r.surf.idw on a large raster. It works well in 6.4.4.
> > I've moved to 7.1 SVN, where everything is marvellous, at least what I
> use,
> > except r.surf.idw which creates the same output as the impot was.
> > I've also svn-ed and compiled 7.0.1, where r.surf.idw did the same.
> There are two issues open:
> https://trac.osgeo.org/grass/query?status=!closed&keywords=~r.surf.idw
> > Namely:
> > r.surf.idw --overwrite --verbose input=output_temp1 output=output_temp2
> > npoints=7
> > when finished, output_temp2 is the same as output_temp1 and no
> interpolation
> > seems to be done.
> > One more big difference:
> > 6.4.4 uses less than 2G ram and finishes in a few minutes. In 7.0 and
> 7.1 it
> > eats all 6GB RAM, 4 GB SWAP and runs much-much longer, understandably...
> This is kind of surprising. Are you sure that the computation region
> was really the same (extent + resolution)?
> Could you provide us with a reproducible example?
> > Should I stay with 6.4.4?
> Likely not :-)
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150518/5c13bcfe/attachment.html>
