[GRASS-user] compiling an addon in grass 7
shashank khare skhare at hotmail.com
Sun May 31 08:56:01 PDT 2015
I downloaded the source from  https://github.com/jontodd/r.refine. I am willing to port it to grass 7 if i get help. I guess the author is not supporting it since there is no commit after 2006. This is my first project on Grass. Is there any  tutorial/documentation on how to to write addons for grass 7? I developed a plugin for qgis and its really easy with so much documentation available online. I wish it were the case with Grass. But nonetheless I want to give Grass a serious try.
Will try with compiled source code today. When i installed grass-dev I do not see the source code of grass on my system. Which dir does it go to?
Thanks
Shashank
> From: neteler at osgeo.org
> Date: Sun, 31 May 2015 14:03:10 +0200
> Subject: Re: [GRASS-user] compiling an addon in grass 7
> To: skhare at hotmail.com
> CC: grass-user at lists.osgeo.org
> On Sun, May 31, 2015 at 7:28 AM, <skhare at hotmail.com> wrote:
>> Hi!
>> I would like to install r.refine addon in grass 7. I have the c/c++ code of
>> r.refine and I installed grass 7 and grass-dev.
> Quick question: Is r.refine online available (for testing)? Do you refer to
> It appears to be written for an older GRASS GIS version.
>> When I compile it keeps giving me error about grass-src directory.
> You can compile like this (example for path) as on my machine:
> make MODULE_TOPDIR=$HOME/software/grass70
> Indeed, you need to have the compiled GRASS GIS source code available for that.
> As Venka wrote:
> sudo apt-get install grass-dev
> will get the source code onto your computer.
> However, the r.refine version needs to be GRASS GIS 7 ready, otherwise
> it won't compile.
> Best
> Markus
