[GRASS-user] location/mapset naming restrictions
Panagiotis Mavrogiorgos pmav99 at gmail.com
Wed Nov 25 16:28:05 PST 2015
Hi all,
Are there any restrictions to the location/mapset names?
I just found out that if you use a numeric mapset (e.g. 2014_123) you have
to use single quotes in mapcalc expressions. e.g the following example will
raise an error:
r.mapcalc expression="foo=R1 at 2014_123"
results in:
syntax error, unexpected INTEGER, expecting VARNAME or NAME
It took me sometime to figure it out,* and in retrospect you can imply this
from the r.mapcalc manual, but I couldn't find any specific reference for
naming restrictions. So, are there any?
with kind regards,
Panos
* actually Nikos Alexandris did...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151126/87cb6541/attachment.html>
