[GRASS-user] problem with t.rast.mapcalc (grass71 daily ubuntu 14.04)
Veronica Andreo veroandreo at gmail.com
Wed Oct 7 06:54:18 PDT 2015
Ops! My bad! Sorry...
Thanks Sören for clarifying this issue...
#2735: t.rast.mapcalc input problem
Reporter:  leohardtke   |      Owner:  grass-dev@…
Type:  defect       |     Status:  reopened
Priority:  normal       |  Milestone:  7.0.1
Component:  Temporal     |    Version:  svn-trunk
Resolution:               |   Keywords:  t.rast.mapcalc
CPU:  Unspecified  |   Platform:  Linux
Changes (by huhabla):
 * status:  closed => reopened
 * resolution:  fixed =>
Comment:
This bug was not fixed in t.rast.mapcalc. A similar bug was fixed in
t.rast.extract. However, fixing the bug in t.rast.mapcalc is more difficult
since it uses a simple search and replace approach to substitute the input
STRDS with map names and is not aware of what a space time dataset is. If
the names of input and output space time datasets are include each other,
then the module does not work properly. Choosing a specific order of the
input STRDS in the input parameter (i.e: input=ndvi_smooth,QA_mask,ndvi)
may reduce the risk of wrong substitution.
However, please use t.rast.algebra instead. This module has other issues
but is able to correctly identify space time datasets.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2735#comment:3>
Vero
2015-10-06 18:16 GMT-03:00 Leonardo Hardtke <leohardtke at gmail.com>:
> Nice!
> El 06/10/2015 16:17, "Veronica Andreo" <veroandreo at gmail.com> escribió:
>> Hola Leo,
>> The problem with basenames was fixed in r66308 (
>> https://trac.osgeo.org/grass/changeset/66308). I've been using basename
>> equal to strds name and works as expected.
>> Enjoy!
>> Vero
>> El sep 9, 2015 3:38 PM, "Leonardo Hardtke" <leohardtke at gmail.com>
>> escribió:
>>> Thaks
>>> If it is a bug, I should fill a bug report so that some developer can
>>> fix it!
>>> Cheers
>>> 2015-09-09 15:17 GMT-03:00 Veronica Andreo <veroandreo at gmail.com>:
>>>> Hi Leo,
>>>> Yes, I had the same problem some time ago and the solution was to
>>>> change the name, as you mentioned...
>>>> Maybe a bug? Dunno :)
>>>> Cheers,
>>>> Vero
>>>> El sep 9, 2015 3:05 PM, "Leonardo Hardtke" <leohardtke at gmail.com>
>>>> escribió:
>>>>> Dear GRASS users (and developers?!),
>>>>> I'm facing a problem with an expression in the t.rast.mapcalc
>>>>> module...
>>>>> t.rast.mapcalc inputs=QA_mask,ndvi,ndvi_smooth_spacetime
>>>>> expression="if(QA_mask==0,ndvi,ndvi_smooth_spacetime)" output=ndvi_fixed
>>>>> basename=ndvi_fixed
>>>>> It throws the following error:
>>>>> Starting temporal sampling...
>>>>> Starting mapcalc computation...
>>>>> Invalid map
>>>>> <MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326_smooth_spacetime_0>
>>>>> Parse error
>>>>> ERROR: parse error
>>>>> ERROR: Error while mapcalc computation
>>>>> The QA_mask maps are:
>>>>> QA_mask_01|PERMANENT|2009-01-01 00:00:00|2009-01-17 00:00:00
>>>>> QA_mask_02|PERMANENT|2009-01-17 00:00:00|2009-02-02 00:00:00
>>>>> The ndvi_smooth_spacetime maps are:
>>>>> ndvi_smooth_spacetime_0|PERMANENT|2009-01-17 00:00:00|2009-02-02
>>>>> 00:00:00
>>>>> ndvi_smooth_spacetime_1|PERMANENT|2009-02-02 00:00:00|2009-02-18
>>>>> 00:00:00
>>>>> The ndvi maps are
>>>>> MOD13Q1.A2009001.h12v12.005.2009019145228_01_4326|PERMANENT|2009-01-01
>>>>> MOD13Q1.A2009017.h12v12.005.2009035110230_01_4326|PERMANENT|2009-01-17
>>>>> M
>>>>> As you see, there is no such a map like..
>>>>> I guess the module is mixing ndvi (a temporal dataset) with
>>>>> _smooth_spacetime... the second part of the name....
>>>>> I know it work ok by renaming the ndvi_smooth_spacetime by something
>>>>> else... but... is this a bug or shoul I use more '`" to protect names !?
>>>>> Thanks!
>>>>> Dr. Leonardo A. Hardtke
>>>>> Laboratorio de Teledetección y S.I.G.
>>>>> Centro Nacional Patagónico (CONICET)
>>>>> Bvd. Brown 2825, 9120
>>>>> Puerto Madryn, Chubut, Argentina
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151007/dfeae817/attachment.html>
