[GRASS-user] Performing a Maximum Likelihood Supervised classification with a single band
Veronica Andreo veroandreo at gmail.com
Thu Oct 8 11:49:56 PDT 2015
Ciao Umberto,
AFAIK, classification is multivariate on its statistical basis, so that's
why it will only take a group as input. If you only have one band, you may
want to extract some information from it, for example by using r.texture
module [1]. With those resulting new bands and the original one you can
create then a group and perform the classification you prefer.
HTH! Cheers,
Vero
[1] https://grass.osgeo.org/grass71/manuals/r.texture.html
2015-10-08 10:53 GMT-03:00 umberto.minora <umberto.minora at unimi.it>:
> I'd like to use i.class and i.maxlik to perform a supervised classification
> of my image. However, it seems i.class only accepts image gropous with more
> than one band. Is there a way or an alternative I can perform such analysis
> with a single band? Thanks in advance.
> http://osgeo-org.1560.x6.nabble.com/Performing-a-Maximum-Likelihood-Supervised-classification-with-a-single-band-tp5228777.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151008/2f2e9ab4/attachment.html>
