[GRASS-user] Reprojection of raster maps in various platforms: projected coordinates are different
Uttam Kumar uttamsinha09 at gmail.com
Thu Oct 8 12:36:42 PDT 2015
Hi All,
This is the projection information of a single Landsat scene in ENVI, GRASS
and using gdalwarp. GRASS and gdalwarp gave somewhat similar output but
ENVI is totally different. I have been informed that the projected image
from ENVI is correct as verified from the earlier work.
Original data (in Sinusoidal Projection)
Corner Coordinates:
Upper Left  (-10801805.198W, 4130102.079N)
Lower Left  (-10801805.198W, 3971252.079N)
Upper Right (-10642955.198W, 4130102.079N)
Lower Right (-10642955.198W, 3971252.079N)
Reprojected in GRASS GIS (Lambert Azimuthal Equal Area, Datum: WGS84)
N:    5564460
S:    5185590                        |
E:   -5451390
W:  -5762490
Reprojected in ENVI (Lambert Azimuthal Equal Area, Datum: WGS84)
Corner Coordinates:
Upper Left  (-2265106.681W, 1064601.383N)
Lower Left  (-2265106.681W,  830181.383N)
Upper Right (-1960126.681W, 1064601.383N)
Lower Right (-1960126.681W,  830181.383N)
Reprojected using gdalwarp (Lambert Azimuthal Equal Area, Datum: WGS84)
Corner Coordinates:
Upper Left  (-5148766.236W, 3000477.570N)
Lower Left  (-5148766.236W, 2724274.973N)
Upper Right (-4826973.503W, 3000477.570N)
Lower Right (-4826973.503W, 2724274.973N)
Any comment is appreciated.
Uttam.
On Sun, Sep 27, 2015 at 1:48 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Sep 26, 2015 1:00 AM, "Uttam Kumar" <uttamsinha09 at gmail.com> wrote:
> > Thank you all. It worked.
> > However I noticed that the projected boundary values of N, S, W and E in
> GRASS are not same as the values obtained from projecting the same image in
> ENVI image processing software and in gdalwarp.
> > Projection of the scene in Lambert Azimuthal Equal Area is similar (but
> not exactly equal) in GRASS and gdal, but in ENVI it is totally different.
> I just did the comparison to see if things are similar from different
> softwares in case they have to be ported to other platforms.
> Can you print the projection information in both GRASS (g.proj -p or -w)
> and ENVI? Are they really the same?
> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151008/6bed2ff6/attachment.html>
