[GRASS-user] Reprojection of raster maps in various platforms: projected coordinates are different
Uttam Kumar uttamsinha09 at gmail.com
Tue Oct 13 12:24:33 PDT 2015
You are right. The scene belongs to a small area near Central California
region.
I have available image boundary in SINUSOIDAL projection in vector format
(shp file). How do I share this to grass users ?
On Thu, Oct 8, 2015 at 12:36 PM, Uttam Kumar <uttamsinha09 at gmail.com> wrote:
> Hi All,
> This is the projection information of a single Landsat scene in ENVI,
> GRASS and using gdalwarp. GRASS and gdalwarp gave somewhat similar output
> but ENVI is totally different. I have been informed that the projected
> image from ENVI is correct as verified from the earlier work.
> Original data (in Sinusoidal Projection)
> Corner Coordinates:
> Upper Left  (-10801805.198W, 4130102.079N)
> Lower Left  (-10801805.198W, 3971252.079N)
> Upper Right (-10642955.198W, 4130102.079N)
> Lower Right (-10642955.198W, 3971252.079N)
> Reprojected in GRASS GIS (Lambert Azimuthal Equal Area, Datum: WGS84)
> N:    5564460
> S:    5185590                        |
> E:   -5451390
> W:  -5762490
> Reprojected in ENVI (Lambert Azimuthal Equal Area, Datum: WGS84)
> Corner Coordinates:
> Upper Left  (-2265106.681W, 1064601.383N)
> Lower Left  (-2265106.681W,  830181.383N)
> Upper Right (-1960126.681W, 1064601.383N)
> Lower Right (-1960126.681W,  830181.383N)
> Reprojected using gdalwarp (Lambert Azimuthal Equal Area, Datum: WGS84)
> Corner Coordinates:
> Upper Left  (-5148766.236W, 3000477.570N)
> Lower Left  (-5148766.236W, 2724274.973N)
> Upper Right (-4826973.503W, 3000477.570N)
> Lower Right (-4826973.503W, 2724274.973N)
> Any comment is appreciated.
> Uttam.
> On Sun, Sep 27, 2015 at 1:48 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Sep 26, 2015 1:00 AM, "Uttam Kumar" <uttamsinha09 at gmail.com> wrote:
>> > Thank you all. It worked.
>> > However I noticed that the projected boundary values of N, S, W and E
>> in GRASS are not same as the values obtained from projecting the same image
>> in ENVI image processing software and in gdalwarp.
>> > Projection of the scene in Lambert Azimuthal Equal Area is similar (but
>> not exactly equal) in GRASS and gdal, but in ENVI it is totally different.
>> I just did the comparison to see if things are similar from different
>> softwares in case they have to be ported to other platforms.
>> Can you print the projection information in both GRASS (g.proj -p or -w)
>> and ENVI? Are they really the same?
>> Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151013/832f6368/attachment.html>
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151013/832f6368/attachment.zip>
