[GRASS-user] locating GRASS installation directories on different operating systems
Rainer M Krug Rainer at krugs.de
Fri Oct 30 04:59:56 PDT 2015
Markus Neteler <neteler at osgeo.org> writes:
> On Thu, Oct 29, 2015 at 3:28 PM, Tyler Smith <tyler at plantarum.ca> wrote:
>> Hi,
>> I'm updating my Emacs grass-mode (available on MELPA, and also here:
>> https://bitbucket.org/tws/grass-mode.el/wiki/Home ).
>> Part of the configuration requires that users tell me where their grass
>> binary, script and documentation files are. Since people may be using
>> different versions, multiple versions, pre-packaged or compiled from
>> source, I can't hard-code paths for this.
> Right.
>>  a reasonably robust way for users to find
>> the information is:
> Please better use this (works "everywhere", also on non-Linux
> systems): ask GRASS itself where it is - of course the startup script
> needs to be in the PATH:
You could always ask for the path to the grass startup script.
> # Linux
> grass70 --config path
> /usr/local/grass-7.0.2svn
> # Windows
> C:\>grass70.bat --config path
> C:\OSGeo4W\apps\grass\grass-7.0
> and so on.
I always forget about the --config options
But how robust is this? I think it is also only supported from 7 onwards
(at least my 6.4.4 installation does not know the argument --config)?
Rainer
> HTH,
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel :       +33 - (0)9 53 10 27 44
Cell:       +33 - (0)6 85 62 59 98
Fax :       +33 - (0)9 58 10 27 44
Fax (D):    +49 - (0)3 21 21 25 22 44
email:      Rainer at krugs.de
Skype:      RMkrug
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20151030/e9df0272/attachment.sig>
