[GRASS-user] exporting map display
Vincent Bain bain at toraval.fr
Wed Sep 9 06:52:11 PDT 2015
Thanks you Anna,
unfortunately I understand d.to.rast cannot handle the content of the
gui default display frame, which is the only display that allows me to
tweak transparency.
My temporary fix was to :
-"set computational region from display extent" ;
-press the button "save display to graphic file", outputting my
composition in a source.png file ;
-then write down a short shell script in this flavor :
eval `g.region -g`
IFS=,
size=($(identify -format %w,%h source.png))
gdal_translate -gcp 0 0 $w $n -gcp ${size[0]} 0 $e $n -gcp ${size[0]}
${size[1]} $e $s source.png target.tif
gcps2wld.py target.tif>target.tfw
This method is certainly not much accurate but it provides me a fast
georeferenced snapshot of a map composition.
Yours,
Vincent
