[GRASS-user] v.import and v.proj errors
Helmut Kudrnovsky hellik at web.de
Tue Aug 2 09:16:57 PDT 2016
>would be anyway useful to clarify what this "datum_trans" option means.
an example of the datum Hermannskogel [1] aka MGI [2].
this datum goes back to the Austrian-Hungary monarchy which covered the area
of Austria, Hungary, Slovenia, etc.
this datum was used in all these countries, but adapted for several regions
(have look at [3]).
this means that you can use the MGI datum for Austria, the Balcan countries
etc, but you have to use different +towgs parameters adapted for the
respective regions/countries which is needed for reprojection.
and here the "datum_trans" option is needed to define these different +towgs
parameters.
HTH
[1] https://de.wikipedia.org/wiki/Datum_Austria
[2] https://de.wikipedia.org/wiki/MGI
[3] http://epsg.io/?q=MGI
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/v-import-and-v-proj-errors-tp5279106p5279130.html
Sent from the Grass - Users mailing list archive at Nabble.com.
