[GRASS-user] Import sqlite table using db.in.ogr
Johannes Radinger johannesradinger at gmail.com
Wed Aug 3 03:35:24 PDT 2016
I am trying to import a sqlite table to my current mapset database
(sqlite). In a further step I want to join the imported table to an already
existing attribute table in my mapset-specific sqlite database.
However I get an error that when I want to import the table. Here an
example where I want to import the "streams" table from the PERMANENT
mapset of the NC location (GRASS7):
db.in.ogr
input=/media/grassgis_data/GRASS_locations/nc_spm_08_grass7/PERMANENT/sqlite/sqlite.db
db_table=streams output=my_test
ERROR: Unable to open data source <streams>
ERROR: Input table <streams> not found or not readable
Here my setup:
GRASS version: 7.1.svn
GRASS SVN revision: 66919M
Build date: 2015-11-25
Build platform: i686-pc-linux-gnu
GDAL: 1.10.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.9
Python: 2.7.3
wxPython: 3.0.1.0
Platform: Linux-3.2.0-106-generic-pae-i686-with-Ubuntu-12.04-precise
Maybe I am missing something, or is that problem known and reproducible
also for others?
Is there another recommended way to import (an join) a database table from
an external sqlite database.
Best regards,
Johannes
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160803/4fab9a1a/attachment.html>
