[GRASS-user] Perform resample a raster using another image as a reference for the process?
Nikos Alexandris nik at nikosalexandris.net
Wed Aug 3 14:17:31 PDT 2016
>Eddison wrote:
>>> >>> Hello thank you very much , you can put some screenshots of the
>>> >>> process?
>Helmut Kudrnovsky:
>>> >> have a look at https://grass.osgeo.org/grass70/manuals/g.region.html
>>> >> -a     Align region to resolution raster=name[,name,...]
>>> See also
>>> https://grasswiki.osgeo.org/wiki/Computational_region
>>> >> Set region to match raster map(s)
>>> >> g.region -a raster=your_raster_you_want_align_to
>Nikos Alexandris:
>>> > Also useful (to read and use):
>>> > https://grass.osgeo.org/grass70/manuals/r.resample.html
>Markus Neteler:
>>> For an overview, see also
>>> https://grasswiki.osgeo.org/wiki/Interpolation
>>> PS: I have now added the second link to all relevant manual pages
>Eddison Araya:
>>Hello thank you very much , then the command is as follows:
>>g.region -a -p raster=lsat5_1987_10 align=urban  ?
>Eddison, the command is as Helmut proposed in one of his first posts
>(see below).
>Essentialy, you want to set the extent of the region (within which
>grass' raster modules will operate) to match a raster map's dimensions.
>That is,
>g.region raster=Your_Raster_Map
>And, even more, you want to force the alignment of the extent to this
>map.  This is done by addin the -a flag:
>g.region -a raster=Your_Raster_Map
>That's it, nothing more.
Eddison, seems I was to fast (and writing out of memory) and your above
command is correct, I guess.  The -a will align the region's extent, to,
well, as the manual explains, the resolution.
So, you'd need your `align=` part.
Nikos
