[GRASS-user] (no subject)
alassane toure atourej at gmail.com
Fri Aug 12 10:05:08 PDT 2016
Group,
I am running a grass-python script but when i replace a variable argument
within the command the script does not work....
The following works...
grass.run_command('r.in.gdal', input='/home/alassane/Data/
SanbornCD/tile/newconstr_mask.tif', output='construction')
But not this...
command="'r.in.gdal', input='"+sys.argv[5]+"', output='construction'"
print 'r.in.gdal command argument... = %s\n ' % command
grass.run_command(command)
r.in.gdal command argument... = 'r.in.gdal', input='/home/alassane/Data/
The following also works...
command ="/home/alassane/Programs/gdal/demclass1"+" "+infile1+" "+infile2+"
"+sys.argv[3]+" "+outfile
os.system(command)
Your help is appreciated.
Regards,
Alassane
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160812/e0a4b66c/attachment.html>
