[GRASS-user] GRASS_VERBOSE=-1
Laurent C. lrntct at gmail.com
Fri Aug 12 16:21:55 PDT 2016
Hello,
One solution is to set the environment variable like this:
os.environ['GRASS_VERBOSE'] = '3'
the other is to pass the verbosity as an argument to run_command(verbose=True)
Cheers,
Laurent
2016-08-12 9:56 GMT-05:00 Micha Silver <micha at arava.co.il>:
> How do I use the VERBOSE=-1 option in a python script?
> I am importing lists of rasters that do not have CRS info (grib2 format), so
> I use the '-o' option to override CRS check. But the screen gets filled
> with:
> WARNING: Datum <unknown> not recognised by GRASS and no parameters found
> WARNING: Over-riding projection check
> and I miss the messages that I want to see.
> Thanks
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
