[GRASS-user] GRASS at the 12th International Conference on Hydroinformatics
Laurent C. lrntct at gmail.com
Sat Aug 13 10:12:36 PDT 2016
2016-08-12 23:28 GMT-05:00 Thomas Adams <tea3rd at gmail.com>:
> Hi Laurent,
> Not sure what I'm doing wrong; I followed the installation using:
> pip install itzi
> which placed itzi here...
> /home/teaiii/.local/lib/python2.7/site-packages/itzi
> Running: itzi run parameter_file_name ... gives me this...
> GRASS 7.0.3 (nc_spm_08_grass7):~/grass/data > itzi run test
> itzi: command not found
> I guess itzi was not installed where it should go or is my PATH not right?
> Tom
Tom,
It looks like a PATH problem. For some reason, pip is not adding the
local bin directory to the PATH when installing with --user, at least
in Ubuntu.
So you might need to add $HOME/.local/bin to your PATH.
Laurent
> On Fri, Aug 12, 2016 at 7:09 PM, Laurent C. <lrntct at gmail.com> wrote:
>> Hello,
>> This message to let you know that I'll give a talk called "A GRASS GIS
>> module for 2D superficial flow simulations" at the 12th International
>> Conference on Hydroinformatics that will be held from 21 to 26 of
>> august in Incheon, Korea. The goal is basically to present Itzï
>> (https://www.itzi.org/), a new superficial flow model that uses GRASS
>> as a back-end.
>> If any other GRASS user will be present at this event, I'll be glad to
>> meet.
>> Of course, I'll be happy if anyone give a try at the software and give
>> me some feed back.
>> Cheers,
>> Laurent
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Thomas E Adams, III
> 1724 Sage Lane
> Blacksburg, VA 24060
> 1 (513) 739-9512 (cell)
