[GRASS-user] Can't load NetCDF after 7.0.4 upgrade
Ken Mankoff mankoff at gmail.com
Mon Aug 15 15:07:46 PDT 2016
Hi GRASS list,
I recently upgraded to 7.0.4 and can no longer open NetCDF files. I re-installed several components at the time of the upgrade, so this may be a gdal or other software error too. I'm not sure how to debug this, and hope someone here can help.
I try to load a variable from a NetCDF file with the following command, which worked last time I ran it in 7.0.3:
r.in.gdal input=NETCDF:foo.nc:var output=ar
I now get the following error:
ERROR 4: No such file or directory
ERROR: Unable to open datasource
       <NETCDF:foo.nc:var>
However, "foo.nc" does exist in the current folder. Read/write permissions is not a problem either. This could be external to GRASS? Part of a gdal compilation issue? But "gdalinfo foo.nc" doesn't have any issues.
I'm on OS X and installed grass 7.0.4 via homebrew, which automatically installed gdal-2.0 for me as a dependency, just as it did for 7.0.3 where everything worked.
Any hints will be much appreciated.
Thanks,
  -k.
