[GRASS-user] topological errors in v.extract results
Markus Metz markus.metz.giswork at gmail.com
Thu Aug 25 09:35:31 PDT 2016
On Wed, Aug 17, 2016 at 11:54 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> I try to compare with GRASS GIS 7.1 but import there is painfully slow.
> So I had at: https://trac.osgeo.org/grass/ticket/2185
> However, I use exactly the same data, from the same database, on the same
> (local) harddrive in 7.1 and it is just !much! slower than 7.0.4 on
> import... Snapping vertices Step 1 takes significantly longer than with
> 7.0.4
G72 and trunk use a new search tree for snapping that needs much less
memory. Unfortunately, balancing this search tree did not scale well
with millions of vertices. I improved the balancing method in trunk
r69253 and G72 r69254.
Markus M
> Cleaning topology in 7.1 from a GRASS vector map earlier imported with
> 7.0.4svn is BTW not noticeably slower in 7.1 compared to 7.0.4...
> I am glad for any hints,
> Stefan
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
