[GRASS-user] flow accumulation values
Micha Silver micha at arava.co.il
Fri Aug 26 00:56:02 PDT 2016
I also noticed that r.stream.extract finds different flow-paths than
r.watershed, which complicates comparisons between the two. The
work-around for this is to use a mask to force r.stream.extract to find
the flow-path you want.
>> r.stream.extract is the preferred stream extraction tool.
> OK, but a flow accum raster is required for running r.stream.order
> (which outputs flow_accum) and AFAIK, the only way to get a flow_accum
> raster is with r.watershed.
BTW, I'm not the only one who has encountered this:
http://gis.stackexchange.com/questions/201118/how-to-obtain-accumulation-map-from-r-stream-extract
Thanks,
> Best,
> Micha
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160826/caedc7f6/attachment.html>
