[GRASS-user] Problems with r.viewshed.cva
Anna Petrášová kratochanna at gmail.com
Tue Aug 30 08:48:54 PDT 2016
On Tue, Aug 30, 2016 at 12:30 PM, Miguel Carrero
<miguel.carrero.pazos at gmail.com> wrote:
> Hi Anna,
> Thanks for replying. The problem seems to be related to r.viewshed. I tried
> to run it as you sugggested, and it didn’t start. So, I removed it and
> re-installed it, and gives me this error:
> Downloading precompiled GRASS Addons <r.viewshed>...
> ERROR: File is not a zip file:
> http://wingrass.fsv.cvut.cz/grass70/x86_64/addons/grass-7.0.3/r.viewshed.zip
r.viewshed is not an addon, but core module. If I remember correctly,
there has been a problem with r.viewshed in 7.0.3 if you are running
64 bit GRASS. Try 7.0.4 or later.
> Miguel.
> De: Anna Petrášová
> Enviado: martes, 30 de agosto de 2016 16:22
> Para: Miguel Carrero
> CC: GRASS user list
> Asunto: Re: [GRASS-user] Problems with r.viewshed.cva
> Hi,
> On Tue, Aug 30, 2016 at 11:14 AM, Miguel Carrero
>> Dear all,
>> I am having problems with r.viewshed.cva addon. I've already re-installed
>> it
>> several times, but the error continues.
>> Note that the routine is constrained to points in the current geographic
>> region.
>> Traceback (most recent call last):
>>   File "C:\Users\Miguel\AppData\Roaming\GRASS7\addons/script
>> s/r.viewshed.cva.py", line 174, in <module>
>>     main()
>> s/r.viewshed.cva.py", line 159, in main
>>     grass.run_command("r.viewshed", quiet = True,
>> overwrite=grass.overwrite(), flags=flagstring, input=elev,
>> output=tempry, coordinates=site[0] + "," + site[1],
>> **viewshed_options)
>>   File "C:\Program Files\GRASS GIS
>> 7.0.3\etc\python\grass\script\core.py", line 394, in
>> run_command
>>     return handle_errors(returncode, returncode, args,
>> kwargs)
>> 7.0.3\etc\python\grass\script\core.py", line 312, in
>> handle_errors
>>     returncode=returncode)
>> grass.exceptions.CalledModuleError: Module run None
>> ['r.viewshed', '--q', 'observer_elevation=0',
>> 'input=dem_cm at Datos_viewshed_ejemplo',
>> 'refraction_coeff=0.14286',
>> 'coordinates=538892.79570571,4756461.28637303',
>> 'memory=800', 'max_distance=-1', 'output=vshed_1\r',
>> 'target_elevation=1.75'] ended with error
>> Process ended with non-zero return code -1073741701. See
>> errors in the (error) output.
>> (Tue Aug 30 17:08:17 2016) Comando finalizado. (0 segundos)
> Module r.viewshed fails, so I would suggest changing
> observer_elevation to a number bigger than zero, although I am not
> sure if that's the problem. Then you can also try running r.viewshed
> itself for one of your points just to check it is running.
> Anna
>> Hope anyone could help. I am using GRASS 7.0.3 in a Windows 10 laptop. I
>> tried to use it 7.0.4 version, and the error is the same as before, but
>> with:
>> WARNING: Illegal filename <vshed_1
>>>. Character <
>>> not allowed.
>> Thanks for the attention,
>> Best,
>> Miguel.
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
