[GRASS-user] PostgreSQL raster and vector import
patrick s. patrick_gis at gmx.net
Wed Feb 3 06:48:53 PST 2016
Dear list
I need some help on importing PostGIS raster with r.in.gdal and schema
support under v.in.ogr.
RASTER:
"r.in.gdal -f" shows support: "PostGISRaster (rw): PostGIS Raster driver"
But I did not find any example on how to formulate the dsn/input.
VECTOR:
Unfortunately there is no hint in the manual of grass70 on how to work
with schemas (there was one in 64).
I had a script in grass64 of following syntax, which is still working:
ISCHEMA=baselayer
v.in.ogr dsn="PG:dbname=psql_local active_schema=my_dataschema"
layer=gws_buildings --overwrite
However, I would like to form this more general as a variable for all
incoming data, which is not working:
INPATH="PG:dbname=psql_local active_schema=my_dataschema"
v.in.ogr in=$INPATH out=bldg_pt layer=gws_buildings --overwrite
=>ERROR: v.in.ogr: Sorry, <active_schema> is not a valid parameter
Also the approach described in the manual of grass64 does not work any
longer
db.connect driver=pg database=psql_local schema=my_dataschema
v.in.ogr in=./ out=bldg_pt layer=gws_buildings --overwrite
=>ERROR: Unable to open data source <./>
Thanks for any help,
Patrick
