[GRASS-user] (re)projection question
Helmut Kudrnovsky
hellik at web.de
Thu Jan 21 13:09:31 PST 2016
Helmut Kudrnovsky wrote
> Ken Mankoff wrote
>> Hi Helmut,
>> On 2016-01-21 at 11:45, Helmut Kudrnovsky <
>> hellik@
>> > wrote:
>>> a quick internet search finds, e.g.
>>> http://geotiff.maptools.org/proj_list/oblique_stereographic.html
>>> maybe a starting point.
>> I'd found that before, but thank you for sending the link again. I made
>> progress on re-reading it.
>>> for a correct Proj.4 string to create a location, it's best to ask in
>>> the
>>> Proj.4 ML.
>> The progress I made, unfortunately, makes me unsure if this is a proj4 or
>> a grass question. But I'm not sure.
>> I don't want to split this thread too much, but decided to try posting on
>> GIS.SE since both communities might see it there.
>> https://gis.stackexchange.com/questions/177763/how-to-define-proj4-string-for-grass
>> I'll post a resolution on this thread if I get an answer there.
> on GIS.SE you posted a link to your data; see there:
> https://nsidc.org/data/docs/daac/nsidc0092_greenland_ice_thickness.gd.html
> " Projection
> All grids are in a polar stereographic projection with reference to the
> WGS84 ellipsoid. The standard parallel is 71°N, and the projection
> parallel (latitude of the center of the projection) is 90°N. The North
> Pole is the origin of the projection. The central meridian is 39°W."
quick test:
locatio wizzard -> create location by proj4 string:
+proj=sterea +datum=wgs84 +lat_0=70.5 +lon_0=40
g.proj -j
+proj=sterea
+lat_0=70.5
+lon_0=40
+k=1
+x_0=0
+y_0=0
+no_defs
+a=6378137
+rf=298.257223563
+towgs84=0.000,0.000,0.000
+to_meter=1
the location is created without any error; just adapt it for your need.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/re-projection-question-tp5246423p5246610.html
Sent from the Grass - Users mailing list archive at Nabble.com.
