[GRASS-user] Trouble importing raster dataset
Thomas Adams tea3rd at gmail.com
Tue Jul 5 14:36:12 PDT 2016
Here is more info from error from gdalinfo...
gdalinfo w001001.adf
Driver: AIG/Arc/Info Binary Grid
Files: .
       ./log
       ./w001001.adf
       ./metadata.xml
       ./hdr.adf
       ./vat.adf
       ./w001001x.adf
       ./prj.adf
       ./sta.adf
       ./dblbnd.adf
Size is 43200, 18000
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AUTHORITY["EPSG","4326"]]
Origin = (-180.000000000000000,90.000007823109627)
Pixel Size = (0.008333333767951,-0.008333333767951)
Corner Coordinates:
Upper Left  (-180.0000000,  90.0000078) (180d 0' 0.00"W, 90d 0' 0.03"N)
Lower Left  (-180.0000000, -60.0000000) (180d 0' 0.00"W, 60d 0' 0.00"S)
Upper Right ( 180.0000188,  90.0000078) (180d 0' 0.07"E, 90d 0' 0.03"N)
Lower Right ( 180.0000188, -60.0000000) (180d 0' 0.07"E, 60d 0' 0.00"S)
Center      (   0.0000094,  15.0000039) (  0d 0' 0.03"E, 15d 0' 0.01"N)
Band 1 Block=256x4 Type=Int16, ColorInterp=Undefined
  Min=0.000 Max=273.000
  NoData Value=-32768
ERROR 3: EOF encountered in ./../info/arc.dir after reading 0 bytes while
trying to read 32 bytes. File may be corrupt.
ERROR 4: Failed to open table ..VAT
On Tue, Jul 5, 2016 at 3:25 PM, Thomas Adams <tea3rd at gmail.com> wrote:
> All:
> I'm unable to import any of the *Monthly Mean PET
> <http://perswww.kuleuven.be/%7Eu0055544/aridity/data/PET_he_monthly.zip>* grids
> from http://csi.cgiar.org/Aridity/ using r.in.gdal GRASS 7.0.3 after I
> expand the .zip file. I keep getting errors referring to "syntax error in
> cell header". It seems the header information in the original file is not
> written correctly.
> Can anyone offer some help?
> Best,
> Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160705/e4cbc788/attachment.html>
