[GRASS-user] UTM 33x
Ken Mankoff mankoff at gmail.com
Sun Jul 17 07:48:20 PDT 2016
Hi Micha and Helmut,
Thanks again for your help so far, and sorry to everyone else for filling your mailboxes on a Sunday morning.
It seems that Micha suggested the fix several emails ago (as did Helmut), which is to try to import into 33N and see what happens. I replied:
> If I follow your advice, it does not work:
> $ grass70 -c epsg:32633 tmp
> GRASS 7.0.3 (tmp): > r.in.gdal input=file.grid  output=file
> ERROR: Projection of dataset does not appear to match current location.
But if you tell GRASS to ignore the data projection, with "r.in.gdal -o", then it does appear to work (especially after dealing with other issues, such as re-setting the region with "g.region raster=file" after importing).
Thank you, Micha and Helmut, for helping me figure this out,
  -k.
