[GRASS-user] "GLdouble" syntax error when compiling GRASS 7.0.4
Markus Neteler neteler at osgeo.org
Thu Jul 21 15:07:09 PDT 2016
Hi Ben,
On Tue, Jul 19, 2016 at 10:01 AM, Benjamin Roberts <ben at roberts.geek.nz> wrote:
> Hi list,
> I’m trying to compile GRASS 7.0.4 on an HPC cluster running Red Hat Enterprise Linux 6.5. We use EasyBuild to manage our toolchain, and I’m compiling GRASS against numerous packages that I’ve previously built, such as PROJ4, GDAL, etc.
Yes fine. BTW: are you aware of this page:
https://grasswiki.osgeo.org/wiki/Compile_and_Install
The closest might be
https://grasswiki.osgeo.org/wiki/Compile_and_Install#Scientific_Linux
which I have used for many years.
> Unfortunately, during the compilation process, I get errors of this sort:
> Error: /home/brob695/.local/easybuild/build/GRASS/7.0.4/foss-2015a/grass-7.0.4/dist.x86_64-pc-linux-gnu/include/grass/ogsf.h:475: Syntax error at 'GLdouble'
> Error: /home/brob695/.local/easybuild/build/GRASS/7.0.4/foss-2015a/grass-7.0.4/dist.x86_64-pc-linux-gnu/include/grass/ogsf.h:475: Syntax error at ';'
> Error: /home/brob695/.local/easybuild/build/GRASS/7.0.4/foss-2015a/grass-7.0.4/dist.x86_64-pc-linux-gnu/include/grass/defs/ogsf.h:178: Syntax error at 'GLuint'
> Error: /home/brob695/.local/easybuild/build/GRASS/7.0.4/foss-2015a/grass-7.0.4/dist.x86_64-pc-linux-gnu/include/grass/defs/ogsf.h:445: Syntax error at 'gsd_set_font'
> Because the objective is to convert data into graphical formats rather than displaying it, we don’t have OpenGL rendering; even the OpenGL libraries and headers are not available.
Is there a chance to install the RPM which contains GL/gl.h?
On my Fedora box that is the mesa-libGL-devel RPM.
> However, I have attempted to disable OpenGL dependency using the --without-opengl configuration option; moreover, I see “checking whether to use OpenGL... no” in my configuration log.
ok, for fun I have removed the OpenGL headers on my Fedora box (along
with some dependent packages) and tried to reproduce your problem. So
I ended up with
  Cairo support:              no
  OpenGL support:             no
  wxWidgets support:          no
Means, I used for configure:
  --with-cairo=no \
  --with-wxwidgets=no \
  --with-opengl=no \
Compiling it as that gave me no errors at all.
> It seems that GLdouble and so forth are OpenGL data types, and presumably therefore I can’t use them without supplying the OpenGL headers.
Yes. Again, it should only be an RPM.
> I’ve tried to find a way to disable OGSF and even NVIZ, thinking that maybe these are dependent on OpenGL in some way, but to no avail.
> Is there something I’ve overlooked that will allow me to work around this problem and get on with a GRASS build without OpenGL?
Please check which configure switches you used.
Maybe send the full configure command to me off-list, in order to take
a look. And also config.log.
Best,
Markus
Markus Neteler
http://www.mundialis.de - free data with free software
http://grass.osgeo.org
http://courses.neteler.org/blog
