[GRASS-user] issues with grass python script running outside grass without defined location
alassane toure atourej at gmail.com
Wed Jun 1 16:41:44 PDT 2016
Thanks Vaclav for your help with the python script running outside grass
when location is predefined.  I am using an example posted in the case of
no existing location and the following error came up...
alassane at alassane-MS-7593:~/Programs/grass/pythongrass$
/home/alassane/Programs/grass/pythongrass/grass_noloc.py
  File "/home/alassane/Programs/grass/pythongrass/grass_noloc.py", line 62
    else:
SyntaxError: invalid syntax
The program works when I comment the followings statements
#  define GRASS DATABASE
if sys.platform.startswith('win'):
    gisdb = os.path.join(os.getenv('APPDATA', 'grassdata')
else:
#    gisdb = os.path.join(os.getenv('HOME', 'grassdata')
    gisdb = os.path.join(os.getenv('/home/alassane/Data', 'grassdata')
#### instruction do not work
Here is the posted code used... Again your help is appreciated.
Alassane
#!/usr/bin/env python
# Python script to generate a new GRASS GIS 7 location simply from metadata
# Markus Neteler, 2014
# ?? LINUX USAGE: First set LIBRARY SEARCH PATH
#export LD_LIBRARY_PATH=$(grass70 --config path)/lib
#python start_grass7_create_new_location_ADVANCED.py
# some predefined variables
# Linux
grass7bin = 'grass70'
#myepsg = '4326' # latlong
myepsg = '3044' # ETRS-TM32, http://spatialreference.org/ref/epsg/3044/
#myfile =
'/home/neteler/markus_repo/books/kluwerbook/data3rd/lidar/lidar_raleigh_nc_spm.shp'
myfile = '/home/alassane/Data/IPDSData/lc80400372013110lgn01_prod_ll.tif'
#myfile = r'C:\Dati\Padergnone\square_p95.tif'
import os
import sys
import subprocess
import shutil
import binascii
import tempfile
########### SOFTWARE
    # we assume that the GRASS GIS start script is available and in the PATH
    # query GRASS 7 itself for its GISBASE
startcmd = grass7bin + ' --config path'
p = subprocess.Popen(startcmd, shell=True,
                     stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = p.communicate()
if p.returncode != 0:
    print >>sys.stderr, 'ERROR: %s' % err
    print >>sys.stderr, "ERROR: Cannot find GRASS GIS 7 start script (%s)"
% startcmd
    sys.exit(-1)
if sys.platform.startswith('linux'):
    gisbase = out.strip('\n')
elif sys.platform.startswith('win'):
    if out.find("OSGEO4W home is") != -1:
        gisbase = out.strip().split('\n')[1]
    else:
    os.environ['GRASS_SH'] = os.path.join(gisbase, 'msys', 'bin', 'sh.exe')
# Set GISBASE environment variable
os.environ['GISBASE'] = gisbase
# define GRASS-Python environment
gpydir = os.path.join(gisbase, "etc", "python")
sys.path.append(gpydir)
else:
# override for now with TEMP dir
gisdb = os.path.join(tempfile.gettempdir(), 'grassdata')
try:
    os.stat(gisdb)
except:
    os.mkdir(gisdb)
# location/mapset: use random names for batch jobs
string_length = 16
location = binascii.hexlify(os.urandom(string_length))
mapset   = 'PERMANENT'
location_path = os.path.join(gisdb, location)
# Create new location (we assume that grass7bin is in the PATH)
#  from EPSG code:
#startcmd = grass7bin + ' -c epsg:' + myepsg + ' -e ' + location_path
#  from SHAPE or GeoTIFF file
startcmd = grass7bin + ' -c ' + myfile + ' -e ' + location_path
print startcmd
    print >>sys.stderr, 'ERROR: Cannot generate location (%s)' % startcmd
    sys.exit(-1)
else:
    print 'Created location %s' % location_path
# Now the location with PERMANENT mapset exists.
# Now we can use PyGRASS or GRASS Scripting library etc. after
# having started the session with gsetup.init() etc
# Set GISDBASE environment variable
os.environ['GISDBASE'] = gisdb
# Linux: Set path to GRASS libs (TODO: NEEDED?)
path = os.getenv('LD_LIBRARY_PATH')
dir  = os.path.join(gisbase, 'lib')
if path:
    path = dir + os.pathsep + path
else:
    path = dir
os.environ['LD_LIBRARY_PATH'] = path
# language
os.environ['LANG'] = 'en_US'
os.environ['LOCALE'] = 'C'
## Import GRASS Python bindings
import grass.script as grass
import grass.script.setup as gsetup
# Launch session and do something
gsetup.init(gisbase, gisdb, location, mapset)
# say hello
grass.message('--- GRASS GIS 7: Current GRASS GIS 7 environment:')
print grass.gisenv()
# do something in GRASS now...
grass.message('--- GRASS GIS 7: Checking projection info:')
in_proj = grass.read_command('g.proj', flags = 'jf')
# selective proj parameter printing
kv = grass.parse_key_val(in_proj)
print kv
print kv['+proj']
# print full proj parameter printing
in_proj = in_proj.strip()
grass.message("--- Found projection parameters: '%s'" % in_proj)
# show current region:
grass.message('--- GRASS GIS 7: Checking computational region info:')
in_region = grass.region()
grass.message("--- Computational region: '%s'" % in_region)
# do something else: r.mapcalc, v.rectify, ...
# Finally remove the temporary batch location from disk
print 'Removing location %s' % location_path
shutil.rmtree(location_path)
sys.exit(0)
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160601/6f37261a/attachment-0001.html>
