[GRASS-user] Problem in deleting a vector map coming from the Vector Digitizer
Rashad Kanavath mohammedrashadkm at gmail.com
Sat Jun 4 05:20:16 PDT 2016
On Sat, Jun 4, 2016 at 11:38 AM, Aldo CLERICI <aldo.clerici at unipr.it> wrote:
> Checked with GRASS for Windows 7.0.1,7.0.2,7.0.3, 7.0.4 *Stand-alone
> installer* under Windows 7,8,10 with many different PCs.
> It seems impossible to delete a map coming from the Vector Digitizer. For
> example:
> 1)      I made a copy of roads (Spearfish Location) named roads_copy_3.
> 2)      I entered the Vector Digitizer with roads_copy_3. I didn’t change
> anything.
> 3)      I quitted the Vector Digitizer with the Quit digitizer button.
> 4)      Trying to delete the map roads_copy_3 I had the following message:
> (Sat Jun 04 01:09:24
> 2016)
> g.remove -f type=vector name=roads_copy_3 at user1
> Removing vector <roads_copy_3>
> WARNING: Unable to delete file
> 'C:\Users\Clerici\Documents\grassdata/Spearfish60_grass7/user1/vector/roads_copy_3/sidx'
Is this a windows path separator issue?
should be
C:/Users/Clerici/Documents/
> WARNING: Unable to delete vector map
> WARNING: <roads_copy_3> nothing removed
> (Sat Jun 04 01:09:25 2016) Command finished (0 sec)
> The cdix, coord, dbln, head, hist component files are lost. Only the sidx
> and topo remain and no other operation on the vector map (copy, rename) can
> be done.
> I have the same result even with new digitized or with existing modified
> maps.
> Thanks in advance.
> Aldo Clerici
> Il 5xmille a favore dell’Università di Parma (indicando il codice fiscale
> 00308780345) è un gesto tanto semplice quanto importante per creare nuove
> opportunità di lavoro per giovani di talento nell'ambito della ricerca
> scientifica.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20160604/a7ad5350/attachment.html>
